Simple Tool to Monitor Bandwidth with solarwinds
Thảo luận trong 'Mua bán thiết bị, dịch vụ mạng' bắt đầu bởi vutri18262028, 1/12/17.
  1. vutri18262028
    vutri18262028 New Member
    SolarWinds' Network Analyzer & Bandwidth Monitoring Bundle (NABMB) captures flow data and monitors interface bandwidth usage in real-time quickly and easily.
    • Quickly analyze traffic on your network by capturing NetFlow data
    • Monitor network bandwidth usage for multiple interfaces in real time
    • Avoid bottlenecks by diagnosing network problems instantly
    Like all SolarWinds tools, Network Analyzer & Bandwidth Monitoring Bundle (NABMB) is quick to deploy and easy to use. And, it’s free!
    DOWNLOAD FREE TOOL
    Need more comprehensive network bandwidth analysis & performance monitoring?
    Add a free trial of SolarWinds Bandwidth Analyzer Pack and immediately start monitoring network availability, performance, bandwidth, and traffic for all your devices!
    LEARN MORE
    Try it free
    Bandwidth hogs slowing you down?
    It’s easy to find the cause of high bandwidth with SolarWinds® NetFlow Traffic Analyzer (NTA). If users are the culprit, NetFlow Traffic Analyzer can help you identify them by resolving their IP address and host name.
    User Device Tracker (UDT) takes this a step further by instantly providing the associated Active Directory® user info, the user’s MAC address, and switch port location. This can save you time having to look at Active Directory logs or tracking the user down through ARP entries and CAM tables. User Device Tracker can also enable you to temporarily disable the port and knock the user off the network.
    DOWNLOAD FREE TRIAL
    " class="CToWUd" style="-x-ignore: 1" width="640" border="0">
    Want to join a community of over 150,000 IT pros and gain direct access to custom templates and reports? Join THWACK ®
    [​IMG] [​IMG] [​IMG] [​IMG]
