Module mở rộng cho Router Cisco ISR4000 Series (ISR4221,ISR4321,ISR4331,ISR4351,ISR4431,ISR4451)
Thảo luận trong 'Routing' bắt đầu bởi tqquang88, 28/9/17.
  1. tqquang88
    tqquang88 Member
    Để chọn lựa Module và Accessories (phụ kiện) mở rộng cho các dòng Cisco ISR 4000 Series, các bạn phải chọn lựa đúng Module và độ tương thích. Các chỉ mục sau sẽ hỗ trợ bạn lựa chọn dễ dàng và chính xác hơn.
    Cisco Layer 2/3 EtherSwitch Modules
    NIM-ES2-4= 4-port Layer 2 GE Switch Network Interface Module
    NIM-ES2-8= 8-port Layer 2 GE Switch Network Interface Module
    NIM-ES2-8-P= 8-port POE/POE+ Layer 2 GE Switch Network Interface Module
    SM-X-ES3-16-P= SM-X EtherSwitch, L2/L3, SM, 16 GE, POE+
    SM-X-ES3-24-P= SM-X EtherSwitch, L2/L3, SM, 24 GE, POE+
    SM-X-ES3D-48-P= SM-X EtherSwitch, L2/L3, SM, 48 GE, 2 SFP, POE+
    Cisco Gigabit Ethernet WAN Modules
    NIM-1GE-CU-SFP= 1-port GE WAN NIM, dual-mode RJ45 & SFP
    NIM-2GE-CU-SFP= 2-port GE WAN NIM, dual-mode RJ45 & SFP
    SM-X-6X1G= SM-X module with 6-port dual-mode GE / SFP
    SM-X-4X1G-1X10G= SM-X module with 4-port dual-mode GE/SFP or 1-port 10G SFP+
    Cisco Serial WAN Interface Modules
    NIM-1T= 1-Port Serial WAN Interface card
    NIM-2T= 2-Port Serial WAN Interface card
    NIM-4T= 4-Port Serial WAN Interface card
    SM-X-1T3/E3= One port T3/E3 Service module
    Cisco Async WAN Interface Modules
    NIM-16A= 16 Channel Async serieal interface for ISR4000 series router
    NIM-VAB-A= Multi Mode VDSL2/ADSL/2/2+ NIM Annex A
    NIM-VA-B= Multi Mode VDSL2/ADSL/2/2+ NIM Annex B
    NIM-VAB-M= Multi Mode VDSL2/ADSL/2/2+ NIM Annex M
    Cisco 4G LTE Network Interface Modules
    NIM-4G-LTE-GA= 4G LTE NIM for Global (Europe, Australia & New Zealand)
    NIM-4G-LTE-NA= 4G LTE NIM for North America AT&T and Canada
    NIM-4G-LTE-ST= 4G LTE NIM for Sprint
    NIM-4G-LTE-VZ= 4G LTE NIM for Verizon
    NIM-4G-LTE-LA= 4G LTE NIM for LATAM and APAC
    NIM-LTEA-EA= CAT6 LTE Advanced NIM for Europe and North America
    NIM-LTEA-LA= CAT6 LTE Advanced NIM for LATAM and APAC
    Cisco T1/E1 Voice and WAN Network Interface Modules
    NIM-1MFT-T1/E1= 1 port Multiflex Trunk Voice/Clear-channel Data T1/E1 Module
    NIM-2MFT-T1/E1= 2 port Multiflex Trunk Voice/Clear-channel Data T1/E1 Module
    NIM-4MFT-T1/E1= 4 port Multiflex Trunk Voice/Clear-channel Data T1/E1 Module
    NIM-8MFT-T1/E1= 8 port Multiflex Trunk Voice/Clear-channel Data T1/E1 Module
    NIM-1CE1T1-PRI= 1 port Multiflex Trunk Voice/Channelized Data T1/E1 Module
    NIM-2CE1T1-PRI= 2 port Multiflex Trunk Voice/Channelized Data T1/E1 Module
    NIM-8CE1T1-PRI= 8 port Multiflex Trunk Voice/Channelized Data T1/E1 Module
    Cisco Analog Voice Network Interface Modules
    NIM-2FXSP= 2-Port Network Interface Module - FXS, FXS-E and DID
    NIM-4FXSP= 4-Port Network Interface Module - FXS, FXS-E and DID
    NIM-2FXO= 2-port Network Interface Module - FXO (Universal)
    NIM-4FXO= 4-port Network Interface Module - FXO (Universal)
    NIM-2FXS/4FXOP= 2-Port FXS/FXS-E/DID and 4-Port FXO Network Interface Module
    NIM-4E/M= 4-Port Network Interface Module - Ear and Mouth
    NIM-2BRI-NT/TE= 2-port Network Interface Module - BRI (NT and TE)
    NIM-4BRI-NT/TE= 4-port Network Interface Module - BRI (NT and TE)
    Cisco Packet Voice Digital Signal Processor Modules (PVDMs)
    PVDM4-32= 32-channel DSP module
    PVDM4-64= 64-channel DSP module
    PVDM4-128= 128-channel DSP module
    PVDM4-256= 256-channel DSP module
    SM-X-PVDM-500= Up to 768-channel DSP module for 4xxx family
    SM-X-PVDM-1000= Up to 1024-channel DSP module for 4xxx family
    SM-X-PVDM-2000= Up to 2048-channel DSP module for 44xx family
    SM-X-PVDM-3000= Up to 3080-channel DSP module for 44xx family
    Cisco UCS E Series Servers
    UCS-EN140N-M2/K9= UCS E-Series NCE, 4-core, 8GB RAM, 1 SSD, NIM
    UCS-E140S-M2/K9= UCS-E,SingleWide,4Cor CPU, 1x8GB SD,1x8GB UDIMM,1-2 HDD
    UCS-E160S-M3/K9= UCS-E, SingleWide, 6 Core CPU, 8 GB Flash, 1-2 HDD
    UCS-E180D-M3/K9= UCS-E, Double Wide, 8 Core, 2.0 GHz CPU,4 HDD
    UCS-E1120D-M3/K9= UCS-E Double-Wide, 12 Core, 1.6GHz Intel Broadwell
    Chúc các bạn có lựa chọn hợp lý
  2. acm_1982
    acm_1982 New Member
    Rất chi tiết và đầy đủ.
