Bộ chuyển đổi RS-232/485/422 sang Ethernet 3onedata
Thảo luận trong 'Mua bán, quảng cáo khác' bắt đầu bởi MCTT, 16/1/22.
  1. MCTT
    MCTT Member
    Chúng tôi MC&TT cung cấp các Bộ chuyển đổi RS-232/485/422 sang Ethernet – Serial Device Server của hãng 3onedata đa dạng với nhiều lựa chọn bao gồm:
    • Bộ chuyển đổi 1 cổng RS-232/485/422 sang Ethernet
    NP301: 1*RS-232/485/422+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    • Bộ chuyển đổi 2 cổng RS-232/485/422 sang Ethernet
    NP302T-2D(RS-232) : 2*RS-232+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    NP302T-2D(RS-485): 2*RS-485/422+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    • Bộ chuyển đổi 4 cổng RS-232/485/422 sang Ethernet
    NP304T-4D(RS-232) : 4*RS-232+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    NP304T-4DI(RS-485) : 4*RS-485/422+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    NP304T-4D(3IN1) : 4*RS-232/485/422(RJ-45)+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    NP314T-4DI(RS-485): 4*RS-485/422+2*10/100Baes-T(X)(dual IPs and MACs), single power supply 12-48VDC, wall-mounting
    NP314T-4D(3IN1): 4*RS-232/485/422(RJ-45)+2*10/100Baes-T(X)(dual IPs and MACs), single power supply 12-48VDC, wall-mounting
    INP314T-4DI-(3IN1)-DB-2P(12-48VDC): 4*RS-232/485/422(DB9)+2*10/100Baes-T(X))(dual IPs and MACs), Dual power supply 12-48VDC, Din-rail
    • Bộ chuyển đổi 8 cổng RS-232/485/422 sang Ethernet
    NP308T-8D(RS-232) : 8*RS-232+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    NP308T-8DI(RS-485) : 8*RS-485/422+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    NP308T-8D(3IN1) : 8*RS-232/485/422(RJ-45)+1*10/100Baes-T(X), single power supply 12-48VDC, wall-mounting
    NP318T-8DI(RS-485): 8*RS-485/422+2*10/100Baes-T(X)(dual IPs and MACs), single power supply 12-48VDC, wall-mounting
    NP318T-8D(3IN1): 8*RS-232/485/422(RJ-45)+2*10/100Baes-T(X)(dual IPs and MACs), single power supply 12-48VDC, wall-mounting
    NP3008T-8DI(RS-485): 8*RS-485/422+1*10/100Baes-T(X), single power supply 85~265VAC, 1U 19″ rackmount
    NP3008T-8D(3IN1): 8*RS-232/485/422+1*10/100Baes-T(X), single power supply 85~265VAC, 1U 19” rackmount
    • Bộ chuyển đổi 16 cổng RS-232/485/422 sang Ethernet
    NP3016T-16D(RS232): 16*RS-232+1*10/100Baes-T(X), single power supply 85~265VAC, 1U 19″ rackmount
    NP3016T-16DI(RS-485): 16*RS-485/422+1*10/100Baes-T(X), single power supply 85~265VAC, 1U 19″ rackmount
    NP3016T-16D(3IN1): 16*RS-232/485/422+1*10/100Baes-T(X), single power supply 85~265VAC, 1U 19″ rackmount
    NP3116T-16D(3IN1): 16*RS-232/485/422+2*10/100Baes-T(X) (dual IPs and MACs), dual power supply 85~265VAC, 1U 19″ rackmount
    NP5100-2T-16DI(3IN1)-RJ-OLED V1.0.0: 16*RS-232/485/422+2*10/100Baes-T(X) (dual IPs and MACs)+OLED,dual power supply 85~265VAC, 1U 19″ rackmount
    NP5100-2T-32DI(3IN1)-RJ-OLED V1.0.0: 32*RS-232/485/422+2*10/100Baes-T(X) (dual IPs and MACs)+OLED, dual power supply 85~265VAC, 1U 19″ rackmount
    Bộ chuyển đổi RS-232/485/422 sang Ethernet của 3onedata hỗ trợ nhiều giao thức mạng, chẳng hạn như giao thức TCP, UDP, ARP, ICMP, HTTP, DNS và DHCP. Nó cũng sở hữu các chức năng quản lý hoàn chỉnh, bao gồm Kiểm soát truy cập, Cấu hình nhanh, Nâng cấp trực tuyến, v.v. Mỗi cổng nối tiếp hỗ trợ 4 kết nối phiên TCP hoặc UDP, và nó cũng hỗ trợ TCP Server, TCP Client, TCP Auto, UDP, Advanced TCP Server, Advanced UDP Operating mode và AT, WEB access mode.
    Hơn nữa, phần mềm cấu hình được cung cấp dựa trên nền tảng Windows có thể hướng dẫn người dùng quản lý và cấu hình thiết bị, giúp kết nối thiết bị nối tiếp ngay lập tức thông qua các cài đặt đơn giản. Nó có thể cung cấp cho người dùng trải nghiệm tốt với thiết kế thân thiện của giao diện hệ thống quản lý mạng, vận hành đơn giản và thuận tiện.
