Bán phân phối thiết bị lưu trữ Synology các loại giá cực tốt
Thảo luận trong 'Mua bán, quảng cáo khác' bắt đầu bởi DOCUHOANGHAI, 13/8/18.
  1. DOCUHOANGHAI
    DOCUHOANGHAI New Member
    Công ty chúng tôi cung cấp và phân phối thiết bị lưu trữ Synology các loại
    Vui lòng liên hệ để có giá tốt:
    Tel/zalo: 0917993131 / 0915793030
    SYNOLOGY PRICE LIST
    Model Description Country of Origin
    EDS14
    *Project model!
    Please contact us
    for better price • CPU Marvell Armada 370 1.2GHz
    • Floating Point Yes
    • Hardware Encryption Engine Yes
    • Memory DDR3 512MB
    • External Device Interface USB 3.0 port X 1, USB 2.0 port X 1, • SD card reader X 1
    • SD Card SDXC/UHS-I, SDHC/C10
    • Size (HxWxD) 31mm X 125mm X 125mm
    • Weight 295g
    • LAN Gigabit X 2 Taiwan
    DS115J • CPU: Marvell Armada 370 800MHz
    • Floating Point: Yes
    • Hardware Encryption Engine: Yes
    • Memory: 256MB DDR3
    • Internal HDD/SSD: 3.5” or 2.5” SATA(II) X 1 (hard drives not included)
    • Max Internal Capacity: 6TB (1 X 6TB HDD)
    • External Ports: USB 2.0 X 2
    • Size (HxWxD) (mm): 166 X 71 X 224
    • Weight: 0.71 kg
    • LAN: Gigabit X 1 Taiwan
    DS116 • CPU Marvell Armada 375 Dual Core 800 MHz
    • Memory 512MB DDR3
    • Internal HDD/SSD 3.5” or 2.5” SATA(II) X 1 (hard drives not included)
    • Max Internal Capacity 6TB (1 X 6TB HDD) (The actual capacity will differ according to volume types)
    • External Ports USB 3.0 X 1, USB 2.0 X 1, eSATA X 1
    • Size (HxWxD) (mm) 165 X 71 X 224
    • Weight 0.7 kg
    • LAN Gigabit X 1 Taiwan
    DS216J • CPU: Marvell Armada 385 88F6820 dual-core 1.0GHz
    • Hardware encryption engine: Yes
    • Floating point unit: Yes
    • RAM size: DDR3 512MB
    • Compatible drive type: 3.5” or 2.5” SATA III/II x 2
    • Max internal raw capacity: 16TB (8TB x 2 hard drives)
    • External ports: USB 3.0 port x 2
    • Size (HxWxD): 165mm x 100mm x 225.5mm
    • Weight: 0.88kg
    • LAN: Gigabit (RJ-45) x 1 Taiwan
    DS216 • CPU Marvell Armada 88F6820 dual-core 1.3GHz
    • Floating point unit Yes
    • Hardware encryption engine Yes
    • RAM size DDR3 512MB
    • Compatible drive type 3.5”/2.5” SATA III/II x 2 (hard drives not included)
    • Max internal capacity 16TB (2 x 8TB hard drive) (The actual capacity will differ according to volume types.)
    • Max single volume size 16TB
    • Hot swappable HDD Yes
    • External ports USB 3.0 port x 2, USB 2.0 port x 1
    • Size (HxWxD) 165mm x 108mm x 233.2mm
    • Weight 1.3kg
    • LAN Gigabit(RJ-45) x 1 Taiwan
    DS218+ • CPU: Intel Celeron J3355 dual-core 2.0 GHz, burst up to 2.5 GHz
    • Hardware encryption engine: Yes (AES-NI)
    • Hardware transcoding engine: Supported codec: H.264 (AVC), H.265 (HEVC), MPEG-2 and VC-1; maximum resolution: 4K (4096 x 2160); maximum frame rate per second (FPS): 30
    • Memory: 2 GB DDR3L (expandable up to 6 GB)
    • Compatible drive type 2 x 3.5" or 2.5" SATA SSD / HDD (drives not included)
    • External port: 3 x USB 3.0 port, 1 x eSATA port
    • Size (HxWxD): 165 x 108 x 232.2 mm
    • Weight: 1.3 kg
    DS216play • CPU: STM STiH412 dual-core 1.5GHz
    • Hardware transcoding engine: Yes; Supported codec: MPEG-4 Part 2 (XVID, DIVX5), MPEG-2, VC-1, H.264 (AVC), H.265 (HEVC); Maximum resolution: 4K (3840 x 2160);
    • Maximum frame rate per second (FPS): 24 (H.264) / 30 (H.265)
    • RAM size: DDR3 1GB
    • Compatible drive type: 3.5”/2.5” SATA III/II x 2 (Hard drives not included. Disk holders are required for 2.5” drives.)
    • Maximum internal raw capacity: 16TB (8TB HDD x 2) (The actual capacity will differ according to volume types.)
    • External ports: USB 3.0 port x 1, USB 2.0 port x 1
    • Size (HxWxD): 165 mm x 100 mm x 225.5 mm
    • Weight: 880g
    DS216se • CPU Marvell Armada 370 800MHz
    • RAM size DDR3 256MB
    • Compatible drive type 3.5”/2.5” SATA III/II x 2 (Hard drives not included. Disk holders are required for 2.5” drives.)
    • Maximum internal raw capacity 16TB (8TB HDD x 2) (The actual capacity will differ according to volume types.)
    • External ports USB 2.0 port x 2
    • Size (HxWxD) 165 mm x 100 mm x 225.5 mm
    • Weight 870g
    • LAN Gigabit (RJ-45) x 1 Taiwan
    DS718+ • CPU: Intel Celeron J3455 quad-core 1.5GHz, burst up to 2.3GHz
    • Compatible drive type: 2 x 3.5" or 2.5" SATA SSD / HDD (drives not included)
    • Size (HxWxD): 157 x 103.5 x 232 mm
    • Weight: 1.74 kg
    • LAN: 2 x 1GbE (RJ-45) Taiwan
    DS418J • CPU: Realtek RTD1293 dual-core 1.4GHz
    • Memory: 1 GB DDR4
    • Compatible drive type: 4 x 3.5" or 2.5" SATA HDD/SSD (drives not included)
    • External port 2 x USB 3.0 port
    • Size (HxWxD): 184 x 168 x 230 mm
    • Weight: 2.21 kg
    • LAN: 1 x 1GbE (RJ-45) Taiwan
    DS418play • CPU: Intel Celeron J3355 dual-core 2GHz, burst up to 2.5GHz
    #Supported codecs: H.264 (AVC), H.265 (HEVC), MPEG-2, VC-1
    #Maximum resolution: 4K (4096 x 2160)
    #Maximum frames per second (FPS): 30
    • Memory: 2 GB DDR3L SO-DIMM (expandable up to 6 GB)
    • Compatible drive type: 4 x 3.5" or 2.5" SATA SSD/HDD (drives not included)
    • External port: 2 x USB 3.0 port
    • Size (HxWxD): 166 x 199 x 223 mm
    • Weight: 2.23 kg
    DS418 • CPU: Realtek RTD1296 quad-core 1.4GHz
    #Supported codec: MPEG-4 Part 2 (XVID, DIVX5), MPEG-2, VC-1, 10-bit H.265 (HEVC)
    • Memory: 2 GB DDR4
    • Weight: 2.28 kg
    DS918+ • CPU: Intel Celeron J3455 quad-core 1.5GHz, burst up to 2.3GHz
    • Memory: 4 GB DDR3L SO-DIMM (expandable up to 8 GB)
    #4 x 3.5" or 2.5" SATA SSD/HDD (drives not included)
    #2 x M.2 NVMe 2280 SSD (drives not included)
    • Weight: 2.28 kg
    DS1517 • CPU Annapurna Labs Alpine AL-314 quad-core 1.7GHz
    • Memory 2 GB DDR3L
    • Compatible drive type 5 x 3.5" or 2.5" SATA SSD / HDD (drives not included)
    • External port
    2 x USB 3.0 port
    2 x eSATA port
    • Size (HxWxD) 157 x 248 x 233 mm
    • Weight 4.15 kg
    • LAN 4 x 1GbE (RJ-45) Taiwan
    DS1517+ (2GB) • CPU Intel Atom C2538 Quad Core 2.4GHz
    • Hardware encryption engine Yes (AES-NI)
    • Memory 2 GB DDR3 SO-DIMM (expandable up to 16 GB)
    2 x M.2 2280/2260/2242 SATA SSD3 (drives not included)
    • External ports
    4 x USB 3.0 ports
    2 x eSATA ports
    • Size (HxWxD) 166 x 250 x 243 mm
    • Weight 4.46 kg
    • LAN 4 x 1GbE (RJ45)
    • Wake on LAN/WAN Yes
    • PCIe 3.0 slot
    1 x 4-lane x8 slot
    10GbE network interface cards support
    M.2 SATA SSD adapter card support Taiwan
    DS1517+ (8GB) • CPU Intel Atom C2538 Quad Core 2.4GHz
    • Memory 8 GB (4 GB x 2) DDR3 SO-DIMM (expandable up to 16 GB)
    • External ports
    4 x USB 3.0 ports
    2 x eSATA ports
    • Weight 4.46 kg
    • PCIe 3.0 slot
    1 x 4-lane x8 slot
    DS1817 • CPU Annapurna Labs Alpine AL-314 quad-core 1.7GHz
    • Memory 4 GB DDR3L (expandable up to 8 GB)
    • Compatible drive type 8 x 3.5" or 2.5" SATA SSD / HDD (drives not included)
    • External port
    2 x USB 3.0 port
    2 x eSATA port
    • Size (HxWxD) 157 x 340 x 233 mm
    • Weight 5.31 kg
    • LAN
    2 x 1GbE (RJ-45)
    2 x 10GBASE-T (RJ-45) Taiwan
    DS1817+ (2GB) • CPU Intel Atom C2538 Quad Core 2.4GHz
    • External ports
    4 x USB 3.0 ports
    2 x eSATA ports
    • Size (HxWxD) 166 x 343 x 243 mm
    • Weight 6.0 kg
    • PCIe 3.0 slot
    1 x 4-lane x8 slot
    DS1817+ (8GB) • CPU Intel Atom C2538 Quad Core 2.4GHz
    • External ports
    4 x USB 3.0 ports
    2 x eSATA ports
    • Weight 6.0 kg
    • PCIe 3.0 slot
    1 x 4-lane x8 slot
    DS2415+ • CPU Intel Atom C2538 Quad Core 2.4GHz
    • Hardware Encryption Engine Yes (AES-NI)
    • Floating Point Unit Yes
    • RAM Size DDR3 2 GB (Expandable up to 6 GB)
    • Internal HDD/SSD 3.5” or 2.5” SATA(II) X 12 (hard drives not included)
    • Maximum Internal Raw Capacity 72 TB (6 TB HDD X 12) (The actual capacity will differ according to volume types)
    • Hot Swappable Drive Yes
    • External Ports USB 3.0 ports X 4, expansion port X 1
    • Size (HxWxD) 270 X 300 X 340 mm
    • Weight 9.24 kg
    • LAN Gigabit X 4 Taiwan
    DS3018xs • CPU: Intel Pentium D1508 dual-core 2.2GHz, boost up to 2.6GHz
    • Memory: 8GB DDR4 SO-DIMM (expandable up to 32 GB)
    #6 x 3.5" or 2.5" SATA SSD / HDD (drives not included)
    #2 x M.2 2280/2260/2242 SATA SSD3 (drives not included)
    • External port:
    #3 x USB 3.0 ports
    #2 x expansion ports
    • Size (HxWxD): 166 x 282 x 243 mm
    • Weight: 5.2 kg
    • LAN: 4 x 1GbE (RJ-45) Taiwan
    DS3617xs
    • CPU Intel Xeon D-1527 quad-core 2.2GHz, burst up to 2.7GHz
    • Memory 16 GB DDR4-2133 ECC SO-DIMM (expandable up to 48 GB)
    • Compatible drive type 12 x 3.5" or 2.5" SATA SSD / HDD (drives not included)
    External ports: 2 x USB 3.0 port, 2 x expansion port
    • Size (HxWxD) 270 x 300 x 340 mm
    • Weight 9.8 kg
    • PCIe 3.0 slot One x8 slot (at 8-lane) Taiwan
    RS217 • CPU Marvell ARMADA 385 88F6820 dual-core 1.33GHz
    • Maximum internal raw capacity 16TB (8TB HDD x 2) (actual capacity depending on volume types)
    • External ports USB 3.0 port x 2, USB 2.0 port x 1, eSATA port x 1
    • Size (HxWxD) 44 mm x 435.6 mm x 291.3 mm
    • Weight 3.46 kg
    • LAN Gigabit (RJ-45) x 2 Taiwan
    RS816 • CPU: Marvell ARMADA 385 88F6820 dual-core 1.8GHz
    • Compatible drive type: 3.5”/2.5” SATA III/II x 4 (hard drives not included)
    • Maximum internal raw capacity: 32TB (8TB HDD x 4) (actual capacity depending on volume types)
    • External ports: USB 3.0 port x 2, eSATA port x 1
    • Size (HxWxD): 44 mm x 430.5 mm x 290 mm
    • Weight: 4.34 kg
    • LAN: Gigabit (RJ-45) x 2 Taiwan
    RS815+ • CPU Intel Atom C2538 Quad Core 2.4GHz
    • Internal HDD/SSD 3.5” or 2.5” SATA(II) X 4 (hard drives not included)
    • Maximum Internal Raw Capacity 24 TB (6 TB HDD X 4) (The actual capacity will differ according to volume types)
    • External Ports USB 3.0 ports X 2, eSATA X 1
    • Size (HxWxD) (mm) 44 X 430.5 X 457.5
    • Weight 6.73kg
    RS815RP+ • CPU Intel Atom C2538 Quad Core 2.4GHz
    • Size (HxWxD) (mm) 44 X 430.5 X 591.8
    • Weight 9.36kg
    RS2416+
    *Project model!
    Please contact us
    for better price • CPU Intel Atom C2538 quad-core 2.4GHz
    • RAM size DDR3-1600 2GB (Expandable, up to 6GB)
    • Compatible drive type 3.5" or 2.5" SATA III / SATA II x 12 (hard drives not included)
    • Maximum internal raw capacity 96TB (12 x 8TB HDD) (The actual capacity will differ according to volume types)
    • Hot swappdable drive Yes
    • External ports USB 3.0 x 2, USB 2.0 x 2, expansion port x 1
    • Size (HxWxD) 88mm x 430mm x 692mm
    • Weight 12.56 Kg
    • LAN Gigabit x 4 Taiwan
    RS2416RP+
    *Project model!
    Please contact us
    • Weight 13.24 Kg
    RS3617xs
    *Project model!
    Please contact us
    for better price • CPU: Intel Xeon E3-1230v2 quad-core 3.3GHz
    • Memory: 4GB DDR3-1600 ECC RAM (expandable up to 32GB)
    • Compatible drive type: 12 x 3.5" or 2.5" SATA 6Gb/s (hard drives not included)
    • Maximum internal raw capacity: 96TB (12 x 8TB HDD) (The actual capacity will differ according to volume types)
    • External ports: USB 3.0 x 2, USB 2.0 x 2, Expansion port (Infiniband) x 2
    • Size (HxWxD): 88 mm x 445 mm x 570 mm
    • Weight: 13.3 kg
    • LAN: 1GbE (RJ-45) x 4
    • PCIe: 3.0 x8 slot Two running at x8 mode, supports two dual-port 10GbE network interface cards Taiwan
    RS3617RPxs
    *Project model!
    Please contact us
    for better price • CPU: Intel Xeon D-1521 quad-core 2.4GHz burst up to 2.7GHz
    • Memory: 8GB DDR4-2133 ECC UDIMM (expandable up to 64GB)
    • Compatible drive: type 12 x 3.5" or 2.5" SATA 6Gb/s (hard drives not included)
    • Maximum internal raw capacity: 120TB (12 x 10TB HDD) (The actual capacity will differ according to volume types)
    • External ports: USB 3.0 x 2, Expansion port (Infiniband) x 2
    • Size: (HxWxD) 88 mm x 430.5 mm x 692 mm
    • Weight: 14.5 kg
    • PCIe 3.0 x8 slot: Two running at x8 mode, supports two dual-port 10GbE network interface cards Taiwan
    RS3617xs+
    *Project model!
    Please contact us
    for better price • CPU: Intel Xeon D-1531 six-core 2.2GHz burst up to 2.7GHz
    • Size (HxWxD): 88 mm x 430.5 mm x 692 mm
    • Weight: 14.5 kg
    • LAN: 10GbE RJ-45 (10GBase-T) x 2, 1GbE RJ-45 x 4
    RS4017xs+
    *Project model!
    Please contact us
    for better price • CPU: Intel Xeon D-1541 8-core 2.1GHz, burst up to 2.7GHz
    • Memory: 8 GB DDR4-2133 ECC UDIMM, expandable up to 64GB
    • Compatible drive type:16 x 3.5/2.5" SATA HDD/SSD
    • External ports: 2 x USB 3.0 port, 2 x Expansion port
    • Size (HxWxD): 132.3 x 430.5 x 624.5 mm, 132.3 x 482 x 656.5 mm (with server ears), 3RU
    • Weight: 17.4 kg
    • LAN: 2 x 10GbE RJ45 (10GBase-T), 4 x 1GbE RJ45
    • PCIe 3.0 slot: 2 x 8-lane x8 slot, High-performance network interface card support Taiwan
    RS18017xs+
    *Project model!
    Please contact us
    for better price • CPU: Intel Xeon D-1531 6-core 2.2GHz, burst up to 2.7GHz
    • Memory: 16 GB DDR4-2133 ECC RDIMM, expandable up to 128GB
    • Compatible drive type:12 x 3.5/2.5" SAS/SATA HDD/SSD
    • External ports: 2 x USB 3.0 port, 1 x Expansion port
    • Size (HxWxD): 88 x 430.5 x 692 mm, 88 x 482 x 724 mm (with server ears), 2RU
    • Weight: 14.5 kg
    RC18015xs+
    *Project model!
    Please contact us
    for better price • CPU Intel Xeon E3 quad-core 3.3GHz
    • Memory 8GB ECC RAM (expandable, up to 32GB)
    • Internal drive N/A (pairing with RXD1215sas is required)
    • External port USB 3.0 x 2, SAS OUT port x 1
    • Size (HxWxD) 44mm x 430mm x 480mm
    • Weight 7.3 Kg
    • System fan Dual fan (40mm x 40mm x 28mm) module x 3
    • LAN Gigabit x 5 (including 1 for Heartbeat connection)
    • PCIe 3.0 x8 slot Add-on network interface card x 1 (optional) Taiwan
    FS2017
    *Project model!
    Please contact us
    for better price • CPU Intel Xeon D-1541 8-core 2.1GHz, burst up to 2.7GHz
    • Memory 16 GB DDR4-2133 ECC RDIMM, expandable up to 128 GB
    • Compatible drive type 24 x 2.5" SAS SSD / HDD or SATA SSD
    • External ports
    2 x USB 3.0 port
    1 x Expansion port
    • Size (HxWxD)
    88 x 430.5 x 692 mm
    2RU
    • Weight 14.9 kg
    • LAN
    2 x 10GbE (10GBase-T)
    4 x 1GbE RJ45
    • PCIe 3.0 slot
    x8 slot x 1 (8-lane)
    10GbE / 25GbE / 40GbE network interface cards support Taiwan
    FS3017
    *Project model!
    Please contact us
    for better price
    • CPU 2 x Intel Xeon E5-2620 six-core 2.4GHz
    • Memory 64 GB DDR4-2133 ECC RDIMM, expandable up to 512 GB
    • External ports 2 x USB 3.0
    • Size (HxWxD)
    88 x 430.5 x 692 mm
    2RU
    • Weight 17.13 kg
    • LAN 2 x 10GbE (RJ45)
    • PCIe 3.0 slot
    x16 slot x 1 (16-lane)
    DX513 • Internal HDD/SSD: 3.5” or 2.5” SATA(II) X 5 (hard drives not included)
    • Expansion Port X 1
    • Hot Swappable HDD: Yes
    • Volume Type: Synology Hybrid RAID, Basic, JBOD, RAID 0, RAID 1, RAID 10, RAID 5, RAID 5+Spare, RAID 6
    • Size (HxWxD): 157mm X 248mm X 233mm
    • Weight: 3.91KG
    • System Fan: 80x80mm X 2
    • Power Recovery Sync with the connected DiskStation (Default Mode)
    • Supported Models: DS710+, DS712+, DS1010+, DS1511+, DS1512+, DS1812+
    • Use as independent volume: DS112, DS112+, DS212+, DS213+, DS412+, DS413 Taiwan
    DX517 • Compatible drive type 5 x 3.5"/2.5" SATA HDD/SSD (drives not included)
    • eSATA port x 1
    • Weight 3.91 kg
    • System fan 2 (80 x 80 x 20 mm)
    • AC input power voltage 100V to 240V AC
    • Power frequency 50 to 60Hz, single phase
    • Power recovery Synchronized with connected Synology DiskStation (Auto Mode)
    • Operating temperature 5°C to 35°C (40°F - 95°F)
    • Storage temperature -20°C to 60°C (-5°F to 140°F)
    • Relative humidity 5% to 95% RH
    • Maximum operating altitude 2,000 m (6,500 ft)
    • Supported NAS models DS1517+, DS1817+ Taiwan
    DX1215 • Internal HDD/SSD 3.5” or 2.5” SATA(III) / SATA (II) X 12 (hard drives not included)
    • Expansion Port 1
    • Hot Swappable HDD Yes
    • Weight 9.02kg
    • System Fan 120x120mm X 2
    • Supported Models DS3615xs, DS3612xs, DS3611xs, DS2413+, DS2015xs Taiwan
    RX415 • Internal HDD/SSD 3.5” or 2.5” SATA(II) X 4 (hard drives not included)
    • eSATA Port X 1
    • Size (HxWxD) 44mm X 430.5mm X 290mm
    • Weight 4.23KG
    • Supported Models1 RS814+, RS814RP+, RS814, RS214 (Independent-volume only) Taiwan
    RX1217
    *Project model!
    Please contact us
    for better price • Compatible drive type 3.5” or 2.5” SATA 6.0Gb/s x 12 (hard drives not included)
    • Expansion port Infiniband x 1
    • Hot swappable drive Yes
    • Size (HxWxD) RX1217: 88 mm x 430.5 mm x 644 mm
    RX1217RP: 88 mm x 430.5 mm x 696 mm
    • Weight 12.7 kg (RX1217) / 13.4 kg (RX1217RP) Taiwan
    RX1217RP
    *Project model!
    Please contact us
    • Size 88 mm x 430.5 mm x 696 mm
    • Weight 13.4 kg Taiwan
    RX1216sas
    *Project model!
    Please contact us
    for better price • Compatible drive type 3.5” or 2.5” SAS / SATA III / SATA II x 12 (hard drives not included)
    • Expansion port SAS IN x 2, SAS OUT x 2
    • Weight 13.5 Kg
    • System fan 4 (80mm x 80mm x 32mm)
    • Power recovery Synchronized with connected Synology RackStation
    • Support Models: RS18016xs+ Taiwan
    RX1217sas
    *Project model!
    Please contact us
    for better price Compatible drive type 12 x 3.5/2.5" SAS/SATA HDD/SSD (drives not included)
    External ports • 1 x SAS IN
    • 1 x SAS OUT
    Size (HxWxD)
    • 88 x 430.5 x 692 mm
    • 88 x 482 x 724 mm (with server ears)
    • 2RU
    Weight 18 kg
    System fan 4 (60 x 60 x 51 mm) Taiwan
    RX2417sas
    *Project model!
    Please contact us
    for better price Compatible drive type 24 x 2.5" SAS/SATA HDD/SSD (drives not included)
    • 1 x SAS OUT
    Size (HxWxD)
    • 2RU
    Weight 16.6 kg
    RXD1215sas
    *Project model!
    Please contact us
    for better price • Compatible drive type 3.5” or 2.5” SAS x 12 (SATA drive is not supported)
    • Maximum internal raw capacity 96 TB (8 TB HDD X 12) (The actual capacity will differ according to volume types)
    • External ports SAS IN x 2, SAS OUT x 2
    • Weight 18 Kg
    • System fan 4 (60mm x 60mm)
    • Power recovery Synchronized with RC18015xs+
    • Support Models: RC18015xs+ Taiwan
    VS360HD • USB: USB 3.0 x 1, USB 2.0 x 2
    • Video output: HDMI x 1, VGA x 1 (mirrored display output)
    • Supported video output resolution: 1920 x 1080 (1080p), 60 Hz
    • Audio input/output: 3.5 mm stereo audio jack x 2 (input/output)
    • Size (H x W x D): 32 x 130 x 130 mm
    • Weight: 300 g
    • LAN: Gigabit x 1 Taiwan
    VS960HD Hardware
    • Video output: HDMI x 2 (Mirrored or extended display output)
    #HDMI1: 4K (3840 x 2160, 30Hz/60Hz)
    #HDMI2: 1080p (1920 x 1080, 60 Hz)
    • Weight: 380 g
    • LAN: Gigabit x 1
    Software
    • Maximum IP camera: 96 (720p at 10FPS)
    • Total FPS (H.264): 960 FPS at 720p, 580 FPS at 1080p, 440 FPS at 3M, 250 FPS at 5M, 140 FPS at 4K Taiwan
    NVR1218 • Configuration: NVR1218 supports up to 12 cameras in total and comes with 4 camera licenses pre-installed.
    • CPU: Embedded NVR SoC dual-core 1.0GHz
    • Memory: DDR3 1GB
    • Compatible drive type: 3.5” SATA x 2 (Hard drives not included)
    • External port: USB 3.0 x 1, USB 2.0 x 2, eSATA x 1, HDMI x 1, 3.5mm audio jack x 2 (input/output), COM x 1 (for POS system connection)
    • Size (HxWxD): 165 x 100 x 225.5 mm
    • Weight: 0.9 kg
    • Supported USB devices: USB storage, keyboard, mouse, joystick, uninterruptible power supply (UPS) Taiwan
    Camera Lic. Pack 1
    • 1 camera license
    * In case of project, please contact us for better price Taiwan
    Camera Lic. Pack 4 • 4 camera licenses
    Camera Lic. Pack 8 • 8 camera licenses
    RKM114 (fixed 1U) Applied models:
    15-series: RC18015xs+, RS815(RP)+, RS815, RX415
    14-series: RS814(RP)+, RS814
    12-series: RS812(RP)+, RS812
    11-series: RS411
    10-series: RS810(RP)+, RX410
    9-series: RS409(RP)+, RS409, RX4
    Taiwan
    RKS1317
    (sliding 1U &2 U) Applied models:
    17-series: RS3617xs, RX1217(RP)
    16-series: RS18016xs+, RS2416(RP)+, RX1216sas
    15-series: RC18015xs+, RXD1215sas, RS815(RP)+, RS815, RS816, RX415
    14-series: RS3614xs+, RS3614(RP)xs, RS2414(RP)+, RS814(RP)+, RS814, RX1214(RP)
    13-series: RS10613xs+, RS3413xs+, RX1213sas
    12-series: RS3412(RP)xs, RS2212(RP)+, RS812(RP)+, RS812
    11-series: RS3411(RP)xs, RS2211(RP)+, RS411, RX1211(RP)
    9-series: RS409(RP)+, RS409, RX4 Taiwan
    E10G15-F1 • IEEE 802.1Q VLAN Tagging
    • IEEE 802.3x Flow Control
    • IEEE 802.3ae 10Gbps Ethernet
    • Full Duplex
    • 9 KB Jumbo Frame
    • Simple Network Management Protocol (SNMP) Agent
    • IEEE 802.3ad Link Aggregation Support
    • TCP/UDP/IP Checksum Offloading
    • Supported OS: Synology DiskStation Manager (DSM) 5.1 and onward
    • Supported Models: RS18016xs+, RC18015xs+, RS3614xs+, RS3614(RP)xs, RS10613xs+, RS3413xs+, RS3412(RP)xs, RS3411(RP)xs, DS3615xs, DS3612xs, DS3611xs
    • SFP+ Cable Support: SFP+ 10GbE Direct Attach Twinax Cables with Connectivity up to 2 Meters Taiwan
    E10G17-F2 Standards:
    CPU Offload (RDMA over Ethernet)*
    Data Transfer Rates: 10 Gbps
    Network Operation Mode: Full Duplex
    Applied Models: FS3017, RS18017xs+, RS18016xs+, RC18015xs+, RS4017xs+, RS3617xs+, RS3614xs+, RS10613xs+, RS3413xs+, RS3617RPxs, RS3617xs, RS3614(RP)xs, RS3412(RP)xs, RS3411(RP)xs, DS3617xs, DS3615xs, DS3612xs, DS3611xs
    Taiwan
    FXC17 • Applied Models FS3017
    • External Ports MiniSAS HD x 1
    • Data Transfer Rates 12Gb/s SAS compliant
    • PCIe Interface PCIe 3.0 8-lane
    • Operating Temperature 5°C to 35°C (40°F to 95°F)
    • Storage Temperature -20°C to 60°C (-5°F to 140°F)
    • Relative Humidity 5% to 95% RH
    Taiwan
    M2D17 Applied Models:
    DS1517+
    DS1817+
    PCIe Interface: PCIe 2.0 x8
    Supported Form Factor: 2280 / 2260 / 2242
    Bracket Height: Low Profile
    Operating Temperature: 5°C to 40°C (40°F to 104°F)
    Storage Temperature: -20°C to 60°C (-5°F to 140°F)
    Relative Humidity: 5% to 95% RH
    Taiwan
    2GB DDR3 1060 • DDR3-1066 unbuffered So-DIMM 204pin CL=7 1.5V
    • Applied models:
    Synology DiskStation: DS2413+, DS1813+, DS1812+, DS1513+, DS1512+
    Synology RackStation: RS2414+/RS2414RP+, RS2212+/RS2212RP+, RS814+/RS814RP+, RS812+/RS812RP+ Taiwan
    RAM1600DDR3-4GB • DDR3-1600 unbuffered So-DIMM 204pin CL=11 1.5V
    • Applied models:
    - Synology DiskStation: DS2015xs, DS2415+, DS1815+, DS1515+
    - Synology RackStation: RS2416+/RS2416RP+, RS815+/RS815RP+ Taiwan
    D3NS1866L-4G RAM module for DS218+, DS718+, DS418play, DS918+ Taiwan
    ECC RAM MODULE
    (DDR3-1333 2GB) RAM module for DS3612xs, DS3611xs, RS3412(RP)xs, RS3411(RP)xs Taiwan
    RAMEC1600DDR3-2GB • DDR3-1333 unbuffered ECC DIMM 240pin CL=9 1.5V
    • Applied models:
    Synology DiskStation: DS3612xs, DS3611xs
    Synology RackStation: RS3412xs/RS3412RPxs, RS3411xs/RS3411RPxs Taiwan
    RAMEC1600DDR3-4GB • DDR3-1600 unbuffered ECC DIMM 240pin CL=11 1.5V
    • Applied models:
    Synology DiskStation: DS3615xs
    Synology RackStation: RS3614xs/RS3614RPxs Taiwan
    RAMEC1600DDR3-8GB • DDR3-1600 unbuffered ECC DIMM 240pin CL=11 1.5V
    • Applied models:
    Synology RackStation: RS18016xs+, RC18015xs+, RS3614xs+, RS3614xs/RS3614RPxs, RS10613xs+, RS3413xs+ Taiwan
    RAM1600DDR3L-4GBX2 RAM module for DS1517+, DS1817+ Taiwan
    RAM1600DDR3L-8GBX2 RAM module for DS1517+, DS1817+ Taiwan
    RAMEC2133DDR4-8GB
    DDR4-2133 unbuffered ECC UDIMM CL=15 Dual Rank 288pin 1.2V
    Applied models:
    Synology RackStation: RS3617xs+, RS3617RPxs
    Taiwan
    RAMEC2133DDR4-16GB DDR4-2133 unbuffered ECC UDIMM CL=15 Dual Rank 288pin 1.2V
    Applied models:
    Synology RackStation: RS3617xs+, RS3617RPxs Taiwan
    RAMRG2133DDR4-16GB DDR4-2133 ECC Registered DIMM CL=15 Dual Rank 288pin 1.2V
    Applied models:
    Synology FlashStation: FS3017
    Synology RackStation: RS18017xs+ Taiwan
    RAMRG2133DDR4-32GB DDR4-2133 ECC Registered DIMM CL=15 Dual Rank 288pin 1.2V
    Applied models:
    RAMEC2133DDR4SODIM- 16GB DDR4-2133 ECC Un-buffered SO-DIMM CL=15 Dual Rank 260pin 1.2V
    Applied models: Synology DiskStation : DS3617xs
    Taiwan
