Module Extreme 1000BASE-LX... 10052H : Module quang 1G Singlemode, 10km, chuẩn kết nối... Module Extreme 1000BASE-T... 10070H : Module quang-đồng 1G, 10/100/1000BASE-T SFP module,... Module Extreme 10GBASE-ER... 10309 : 10GBASE-ER SFP+, 1550nm, LC Connector, transmission... DAC Extreme 10G SFP+ CU... 10304 : 10G SFP+ CU direct attached passive twin-ax copper cable... Module Extreme 1000BASE-SX... 10051H : Module quang 1G Multimode, 550m, chuẩn kết nối... Module Extreme 1000BASE-ZX... 10053H : 1000BASE-ZX, SFP, Hi, SMF (1550nm wavelength) up to... Module Extreme 1000BASE-BX-D... 10056H : 1000BASE-BX-D, SFP, Hi, SMF (1490nm TX/1310nm RX wavelength)... DAC Extreme 10G SFP+ CU... 10305 : 10G SFP+ CU direct attached passive twin-ax copper cable... Module Extreme 1000BASE-BX-U... 10057H : 1000BASE-BX-U, SFP, Hi, SMF (1310nm TX/1490nm RX wavelength)... Module Extreme 100FX/1000LX... 10060H : Dual-Speed 100FX/1000BASE-LX, SFP (1310nm wavelength)... Module Extreme 100FX SFP... 10063 : 100BASE FX, SFP, MMF (1310nm wavelength) up to 2km, 125MbpsX10,... DAC Extreme 10G SFP+ CU... 10306 : 10G SFP+ CU direct attached passive twin-ax copper cable... Module Extreme 10GBASE-SR... 10301 : Module quang 10G Multimode, 300m, chuẩn kết nối... Module Extreme 10GBASE-LR... 10302 : Module quang 10G Singlemode, 10km, chuẩn kết nối... Module Extreme 10GBASE-LRM... 10303 : 10 Gigabit Ethernet SFP+ LRM, 220m MMF, LC Liên hệ để có giá tốt DAC Extreme 10G SFP+ CU... 10307 : 10G SFP+ CU direct attached passive twin-ax copper cable... Module Extreme 10GBASE-ZR... 10310 : 10GBASE-ZR SFP+, 1550nm, LC Connector, transmission... Liên hệ Tel/zalo: 0917993131 / 0915793030
