AirPods Pro Rebuilt from the sound up. Learn more Which AirPods are right for you? Compare all AirPods models Get six months of Apple Music free with your AirPods.6 Learn more Find a Reseller | 120-65-104 1. Compared to AirPods Pro (1st generation). 2. Compatible hardware and software required. Works with compatible content in supported apps. Not all content available in Dolby Atmos. iPhone with TrueDepth camera required to create a personal profile for Spatial Audio, which will sync across Apple devices running the latest operating system software, including iOS, iPadOS (coming later this year), macOS (coming later this year), and tvOS. 3. MagSafe charging requires a compatible MagSafe charger. Wireless charging requires a Qi-certified wireless charger. AirPods Pro (2nd generation) charging case also works with the Apple Watch charger or Lightning connector. 4. Testing conducted by Apple in August 2022 using preproduction AirPods Pro (2nd generation) with MagSafe Charging Case and software paired with preproduction iPhone 14 Pro Max units and software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50 percent and Active Noise Cancellation was enabled. With Spatial Audio and Head Tracking enabled, listening time was up to 5.5 hours. Testing consisted of full AirPods Pro battery discharge while playing audio until the first AirPod Pro stopped playback. Battery life depends on device settings, environment, usage, and many other factors. 5. Testing conducted by Apple in August 2022 using preproduction AirPods Pro (2nd generation) with MagSafe Charging Case and software paired with preproduction iPhone 14 Pro Max units and software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50 percent and Active Noise Cancellation was enabled. Testing consisted of full AirPods Pro battery discharge while playing audio until the first AirPods Pro stopped playback. The drained AirPods Pro were charged to 100 percent, then audio playback was resumed until the first AirPods Pro stopped playback. This cycle was repeated until both the AirPods Pro and charging case were fully discharged. Battery life depends on device settings, environment, usage, and many other factors. 6. New subscribers only. 65,000đ/month after trial. Offer available for a limited time to new subscribers who connect an eligible device to an Apple device running iOS 15 or iPadOS 15 or later. Offer good for three months after eligible device pairing. No audio product purchase necessary for current owners of eligible devices. Plan automatically renews until cancelled. Restrictions and other terms apply.
